Skip to main content
Allow higher 4K export bitrate (100,000 kbps+)
When I export 4K/60, FocuSee tops out around ~54,000 kbps, which makes fast motion and fine UI text look a bit soft. Please add a higher bitrate preset (e.g., 100,000–120,000 kbps) or a custom bitrate field so we can export sharper videos.
Status: Completed2 comments
Log in to comment and vote
Comments2
  • FocuSee Product Team
    Team•
    Aug 20, 2025
    Hello, thank you very much for your valuable suggestion! We’ve received your feedback. Could you let us know how often the current bitrate limit fails to meet your needs? Your request for a “custom bitrate option” has been noted and will be discussed in our future product planning. Your feedback is very important to us, and we truly appreciate your support. If you have more ideas or needs, please feel free to share them with us anytime.
    • Phil Evans
      Aug 22, 2025
      Thanks for the quick response! The current 4K/60 cap (~54,000 kbps) falls short on most of my projects—especially when there are fast pans/auto-zooms, motion blur, or small UI text. When I record the same content with Nvidia’s ShadowPlay at 4K/60 ~130,000 kbps, the image is noticeably crisper when I view it.
      Request: please add a “Max Quality” preset (~100,000–130,000 kbps) or a custom bitrate field so we can push higher targets for 4K/60 exports.
