Skip to main content
Allow Transparent BG
I see your previous response to someone where you said to set padding to 0. This works except when you try to use a aspect ratio like 9:16 and you record something thats 16:9. It would be lovely to be able to export the 3d recording with transparent background for us to set out own. also is very needed to add demo videos onto landing pages.
I don’t see this being anything hard to do since the recording is already being placed separately onto a preset bg.
Please consider this feature. Thanks team!
4 comments
Log in to comment and vote
Comments4
  • FocuSee Product Team
    Team•
    Apr 23
    Thank you for your suggestion. We will prioritize fixing the issue where 9:16 videos do not fill the frame, and will consider supporting transparent backgrounds and custom backgrounds in future updates.
    • fx5.expert.advisor@gmail.com
      Apr 28
      Is this what has been changed in the new update? also could you strongly consider allowing old versions to remain available after an update as a form of a downgrade button somewhere in the software? Things like this change the functionality of the app and sometimes a new update is undesirable.
        Team•
        May 6
        Thank you for your suggestion. We will consider this feature.
    Apr 22
    Also, exporting with a transparent background natively can allow us to keep the shadow which will be awesome.
