Skip to main content
BUG macOS - Big red rectangle next to default cursor
When I select the default (first) cursor from the list after recording, I can see a huge red rectangle next to it, following its movement as well. The rectangle’s size changes according to the cursor’s size. It’s the only cursor that does that, the other ones are just fine:
macOS 14.7.5 (23H527)
Retina 5K, 27-inch, 2019 iMac
3.6 GHz 8-Core Intel Core i9
Radeon Pro 580X 8 GB
128 GB 2667 MHz DDR4
Status: Completed1 comment
Log in to comment and vote
Comments1
  • FocuSee Product Team
    Team•
    May 15, 2025
    Dear FocuSee User,
    Thank you for your feedback. I’ve forwarded your issue to our technical and support teams. To help us locate the problem more efficiently, you can also send your log file directly to our customer service team at cs@imobie.com. This will greatly assist in speeding up the troubleshooting process. Thank you for your cooperation and support!
    Best regards,
    From Focusee Product Team
