Create presets
Different videos for different brands or for your channel, should have different but consistent styles. It would be great if there was an option for presets that you use for your videos. (zoom, cursor, frames, padding, radius and background settings)
Log in to comment and vote
Comments6
Jun 3, 2024
May 31, 2024
CN
Feb 28, 2024
Definetly a MUST!
Another setting tha should be in this presets is the ability to set the automatic minimum time that the zoom is applied.
I feel that today the zoom has persisted for much longer than it should have, requiring many adjustments in editing.
Mitchal Majors
Feb 4, 2024
The availability of custom presets along with a user-defined default would streamline content creation for multiple styles (how-to, tutorial, etc.) in long runs.
Jan 2, 2024
hi@damartech.com
Jan 2, 2024
Yes, it would be great to have presets or save the last settings when you open again. I want to keep the camera on the bottom right, with mirrored camera, keep padding to smaller value, rounded edge to smaller value etc. Now I have to do this for each new video I record. When we create a new recording, everything falls back to default and we have to do the adjustments all over again. So it would be great to save these settings as presets and apply all in one go, or just make the app to remember the last settings and keep it that way. It would save a lot of time and repetitive actions.
