Skip to main content
Cursor to a ‘pointer cursor’ when hovering over clickable elements
FocuSee doesn’t currently change the cursor to a “pointer cursor” (hand icon) when you hover over clickable elements like links. Adding this feature would make it easier for viewers to see which parts of the video are interactive. Other software already has this, and it helps make videos more clear and user-friendly. It would be great to see this added in a future update.
Status: Completed6 comments
Log in to comment and vote
Comments6
  • hjorte@gmail.com
    Jan 2, 2025
    I find the issue to be intermittent.
  • hjorte@gmail.com
    Jan 2, 2025
    Dariusz, the previous version did work, but this latest version does not. I have projects made in the previous version, which shows the macOS hand pointer when hovering over links.
    It must be a bug.
    • dariuszniemczak@gmail.com
      Jan 2, 2025
      Henrik Thank you for the reminder!
      You’re right, this feature might have worked in the previous version. I also thought I had seen it before, but I wasn’t completely sure. I appreciate you pointing it out!
      • FocuSee Product Team
        Team•
        Mar 13, 2025
        Dear FocuSee User,
        Thank you for your valuable feedback on FocuSee! We have indeed made optimizations for Zoom, and to meet the needs of most users and provide a better recording experience, we have improved the mouse recognition rules. We apologize for any inconvenience this may have caused. We will record your request and pass it on to our product manager. Thank you for your support and understanding!
        Best regards,
        From Focusee Product Team
    • hjorte@gmail.com
      Jan 2, 2025
      Dariusz, I have now reported it as a bug directly from the app (Send feedback). You should do the same.
      Team•
      Mar 13, 2025
      Dear FocuSee User,
      Best regards,
