Skip to main content
How to save a project?
Do you know how to save a project to continue working on it later?
Status: Closed4 comments
Log in to comment and vote
Comments4
  • mattolhm@gmail.com
    May 21, 2025
    Is there a solution for this? I used to be able to save as project in Version 1.2, but I can’t find the function after updating to version 1.4.
    • FocuSee Product Team
      Team•
      May 30, 2025
      Thank you for your feedback. Regarding the save function you mentioned, we haven't made any changes to it. If you are unsure whether the save was successful, we recommend that you manually save using the Ctrl+S shortcut. After saving, you can find the file in "File" - "History".
  • Taz Goldtein
    Sep 5, 2024
    I've been trying to find the save command for 20 minutes. Came here and found this feedback.
    I agree with Cait wholeheartedly. FocuSEE desperately needs a legitimate save command. FocuSEE is known to crash from time to time. This can and WILL result in hours of lost work. I already lost time due to this. Not having the ability to save without closing the project is a pretty glaring omission.
  • Morgan Kung
    Jan 17, 2024
    Yes, you can re-edit projects. Just find the projects as the screenshot shows 👇
