Il serait bien d'avoir des options pour éditer l'audio ou avoir deux séparate tracts, recorded pour microphone audio et system audio. La volume enhancement option est très bonne, mais il sera plus efficace à avoir une option de gain tracts by adding 1db option button.
It would be good to have options to edit audio or to have two separate tracks recorded for microphone audio and system audio. The volume enhancement option is very good, but it would be more effective to have a gain control for tracks, for example an "Add 1 dB" button. 😀 Thanks amazing App!
Log in to comment and vote
Comments2
FocuSee Product Team
Apr 27
Hi, thank you for your suggestion. Could you let us know in what scenarios you would typically use this feature?
info@pascallamarche.com
Apr 27
Thank you for your response! 🙏
I often record videos for my fellow musicians using my headphone microphone, and I also need to capture my system audio. For some reason, the system audio track is always recorded at a very low volume, so I have to boost it afterward.
Even with the 3× volume enhancement option, it’s still not loud enough. It would be great to have an option to increase the volume in smaller increments (e.g., +1 dB), so I can adjust it precisely to my desired level.
Alternatively, giving access to the two separate audio sources—microphone audio and system audio—so I can edit their waveforms independently would be extremely helpful.
Thanks!
