Skip to main content
Keyframes for Animation
Especially for 3D animations on screen recordings, it would be nice to have keyframe ability to specifically control the animations more granularly.
Primarily on the “zoom” portion, having the ability to set keyframes that capture various configurations, then transition or animate between the differences in the keyframes, would be really useful.
3 comments
Log in to comment and vote
Comments3
  • FocuSee Product Team
    Team•
    Sep 7
    Thank you for your suggestion. We have recorded it and will pass it to our product team for future evaluation.
    More granular keyframe control could make animation and zoom editing more flexible, especially for users who need precise control over movement, scale, timing, and transitions between different visual states.
    If convenient, please feel free to share which controls you would most like to keyframe, such as zoom scale, position, 3D angle, duration, easing, or camera movement. This will help us better understand the workflow and evaluate the priority.
    • Bryson Loughmiller
      Sep 7
      Honestly, all of those would be great to have as a part of keyframe capabilities. Zoom/Scale/Position/Angle are probably the most critical, camera movement and duration would also be helpful
        Team•
        Sep 9
        Thank you for the clarification. Some of these controls are already available for manual adjustment in FocuSee.
        As shown in the screenshot, you can select the 3D Motion/Zoom segment on the timeline, switch the setting from Auto to Manual, and then adjust related parameters such as zoom level, tilt, position, and manual focus.
        Could you please confirm whether this manual adjustment workflow meets your main need? Or are you specifically looking for a true keyframe workflow where you can set multiple points with different zoom/scale/position/angle values and have FocuSee automatically animate the transition between them? If it is the latter, we will keep that as a separate feature request for further product evaluation.
        用户附件
