Skip to main content
More options to control hide cursor when idle
There needs to be more options to control the mouse cursor when idle. Other apps like Screen Studio let you set how many seconds of it being idle before the cursor hides. And also it should have a smooth fade in/out when it hides, not just disappear with no animation.
Status: Completed3 comments
Log in to comment and vote
Comments3
  • FocuSee Product Team
    Team•
    Jun 26
    Thank you for your suggestion. We have recorded it.
    The setting for automatically hiding the mouse cursor after it has been idle for a certain amount of time is already supported, similar to Screen Studio. You can check and adjust it in the recording-related settings. If you cannot find the option, or if the result does not work as expected after changing the setting, please feel free to share your app version, operation path, and any related screenshots so we can help confirm it further.
    We will also include the other experience improvements in our future evaluation.
    • estarno
      Jun 26
      Yes I see that option and it works, but I am suggesting you add more control to the feature such as being able to set how long the cursor must be idle before it hides. For my needs, it is a bit too long. And as mentioned, it would be nice to have a slight fade out as it hides and re-enters rather than it abruptly hiding. Thank you.
        Team•
        Jun 29
        Thank you for the clarification. We have recorded it and will include it in our future product evaluation. This direction could be very helpful for improving recording control and the final video experience.
