Skip to main content
More recordings to add on timeline
do not understand why this should not be possible. If you misspeak you have to start new projects over and over again?
Status: In Progress44 comments
Log in to comment and vote
Comments44
  • Bruno Lapeyre
    Sep 2, 2025
    A capture tool like yours, which seems very interesting and has great features, doesn’t hold up, in my opinion, without the ability to edit and add multiple external videos. With this functionality, the possibilities are endless.
    It allows me, on one hand, to fix mistakes, but also to bring in videos I’ve created elsewhere to truly craft tutorials and presentations. Right now, without the ability to add additional videos, I feel so restricted.
    Honestly, I strongly recommend implementing this—it will completely transform the potential of your tool.
  • maosn wu
    Apr 25, 2025
    Thank you for your feedback. We are currently discussing a solution for this suggestion and considering adding it to our near-term plans. Could you please tell us when or under what circumstances you would use this feature?
    • raf.degreve@gmail.com
      Apr 25, 2025
      a project can involve multiple recordings? I am recording myself for 10 minutes, if I make one single speaking error, I have to delete everything and start all over again. Recording smaller good pieces and connect them to each other would be super handy. For that reason I still need to use Camtasia..
  • ar-enty
    Oct 29, 2025
    In my workflow, I often finish a recording and later realise I need to continue or add another part. Right now, the only way to do this is by recording a new video and then merging clips in an external editor, which is time-consuming.
    It would be great to have a “Continue Recording” or “Add Clip” option that lets me start a new segment and automatically append it to the same project/timeline inside FocuSee.
    This would make it much easier to record tutorials, multi-part demos or explanations without having to re-edit everything afterward.
    Thanks for considering this — I’d be happy to test it if you release a beta version!
    • FocuSee Product Team
      Team•
      Oct 30, 2025
      Thank you for your feedback! The multi-segment recording feature is already included in our future development plan. We’d love to hear more insights and suggestions from users to help us improve it.
      Would you be interested in joining a short email interview to share what problems you’d like this feature to solve and what your ideal workflow would look like? Your input will help us make the feature more aligned with real user needs.
      • ar-enty
        Oct 30, 2025
        Yes, I’d be happy to join the email interview and share more details about my workflow.
        I could also sketch a quick mockup to illustrate how I imagine the “Continue Recording” flow.
        Could you please let me know the best way to share my contact information privately?
          Team•
          Oct 31, 2025
          You can send an email to our product team at product@imobie.com, and we will be able to contact you via email. We look forward to hearing from you!
  • tverdouw@gmail.com
    Nov 25, 2025
    I've seen in several places that this feature is on the roadmap, even mentioned in this conversation seven months ago. Is there any ETA for its release? As a video creator, this is essential. As others have noted, when you make a mistake during recording, you have to retake and export both recordings to edit them with an external editor, which is super inefficient.
  • hello@soundhaus.studio
    Jan 16
    Any progress on this? It’s table stakes for me. I’m not sure I’ll invest in it if I can’t. Would be a fantastic addition and solve a lot of issues for users of most modern video editing tools. Thanks in advance for considering it!
    Team•
    Jan 19
    Thank you for your suggestion. We are already researching a solution for recording multiple videos within the same project. If you have any further suggestions regarding this feature, please feel free to share them. Thank you.
  • ushi.cow.happiness2014@gmail.com
    Jan 31
    I’ve been using FocuSee for over a year, and there’s one major workflow issue that keeps coming up.
    Because FocuSee can’t add multiple recordings/clips into a single timeline and merge them, I’m forced to use a separate video editor every time just to stitch clips together. This adds unnecessary steps, slows me down significantly, and honestly makes the overall experience feel far less usable than it could be.
    I also update my videos frequently, so I often need to replace or insert a small section. However, in FocuSee I can’t insert a new clip into an existing project, reorder clips, or swap only a specific part. As a result, even minor updates often require me to re-record the entire video, which is extremely time-consuming and frustrating.
    What I strongly request is:
    • The ability to add multiple recordings (or imported video files) to the same timeline
    • Insert / reorder / replace clips on the timeline
    • Ideally, the option to add new recordings to an existing project later
    If this is implemented, FocuSee would become a truly complete “record + edit + export” solution, and I would confidently recommend it to many more people. Please prioritize adding this functionality.
      Team•
      Feb 2
  • Frank Velez
    Feb 26
    It would be great if not only can we add multiple recordings, but also
    be able to add multiple audio files or even just a background music track.
    And maybe don't know how difficult it would be, but you could potentially show two screens at once with your 3D animation. You can move one of the videos to the left or to whatever position, plus adjust the tilting, etc. You can also allow a second video to be on the other part of that screen.
      Team•
      Feb 27
      Thank you for your suggestion. We will gradually improve support for multiple screens and multiple audio sources.
  • kunal.dhawan14@gmail.com
    Apr 2
    Merged request
    8 votes
    Rearranging video splits
    Please add functionality to rearrange the video splits, I have to export the file and then edit the video in iMovies just for this
    Having this functionality would make it super simple to record tutorial videos and edit directly in Focusee
      Team•
      Jan 12
      Thank you for your suggestion. Could you share how you typically use this feature?
      • Frank Velez
        Jan 20
        I think this would just be good if there were just a clip throughout the entire video that you wanted to take from whenever you got it and move it for instance to the first part of the overall video.
        As well as letting us just import more than one video to splice together.
      Team•
      Jan 21
      Thank you for your suggestion. We are already researching a solution for recording and edit multiple videos within the same project. If you have any further suggestions regarding this feature, please feel free to share them. Thank you.
  • N. Son Tran
    Apr 2
    Merged request
    8 votes
    Record more clip in 1 go
    I want to Record more clip in 1 go
      Team•
      Jun 16, 2025
      Dear FocuSee User,
      Thank you for your feedback! Our product team has received your suggestion and will carefully evaluate it in future planning. Your input is highly valuable to us—feel free to continue sharing your thoughts and experiences!
      Best regards,
      From Focusee Product Team
      • calebbrideau@gmail.com
        Feb 24
        We need this feature sooner than later, I absolutely love the program but would argue this may be holding yout sucess back a bit, it should be standard in a video editor to be able to add recordings videos usually take more than one shot. Hoping this will make it in soon!
          Team•
          Feb 24
          Thank you for your feedback. We are currently researching possible solutions for this feature.
