Skip to main content
One click remove all zooms
Sometimes you want to be specific and manually add zooms to really control your results. Today, I have to select all zooms one by one and then delete.
Status: Completed5 comments
Log in to comment and vote
Comments5
  • Steven L
    Feb 6
    I swear there was one click remove all zoom previously…did it get removed?
    • FocuSee Product Team
      Team•
      Feb 9
      This wasn’t supported before, but you can turn off zoom generation before you start recording.
  • brianstiroh@gmail.com
    Feb 4
    I completely agree. This would be huge. Even as simple as dragging a selection over the timeline and deleting all of the zooms/events you select.
      Team•
      Feb 6
      Thank you for your suggestion. We are in the process of addressing this issue.
    Team•
    Jan 28
    I apologize for the inconvenience. We will soon launch the copy and paste properties feature, which will allow you to quickly adjust your zoom levels. In the future, we will also support one-click removal of all zoom keyframes.
