Skip to main content
Open project
It would be good to be able to open earlier projects from the UI. Now I need to find the folder they are located in and open it from there. Possibly having a “Recent projects” somewhere in the settings, etc.
Status: Completed1 comment
Log in to comment and vote
Comments1
  • FocuSee Product Team
    Team•
    May 8, 2025
    Thank you for your feedback. What operating system are you using? You can find all your history projects by clicking on the alarm clock icon on the right side of the top menu. If you are using Windows, you can also find "History" in the File option in the top menu, click it to display all your history functions.
