PLEASE FIX 3D MOTION
This new update changed the Auto 3d motion and it is absolutely terrible. Please for the love of god change it back or let me go back to a previous update
Log in to comment and vote
Comments19
fx5.expert.advisor@gmail.com
Apr 15
Seriously I have gone back to my previous files and opened them up in the editor, and everything with the zoom as changed, it genuinely looked nothing like how it did prior to the update and was the only reason I paid for the lifetime license- the amazing zoom it was before
FocuSee Product Team
Apr 15
Hi, the version update will not modify your previous project files. If you do not want to use 3D, you can simply select zoom and switch to 2D mode—we have provided this option. Additionally, could you let us know what aspects of the 3D zoom effect you feel are not working well?
Apr 15
I appreciate the fast reply, the “project files” that have not been exported yet are now different when i reopen them up in the editor, something has most definitely changed. Could you guys please allow us to download the previous version right before the annnotation feature update so I can confirm it was the update that changed things? I was in love with the old 3d zoom feature, it truly is now not the same and requires manually adjusting bars to get the old 3d zoom feature back
Apr 15
We introduced the annotation feature in version 2.3. You may try it before making a decision. If you do not want to use 3D, you can set the zoom mode to 2D zoom in the settings menu.
Apr 15
I DO want the 3d motion, it was what set this tool apart from everyone else. Please allow for the ability to download older versions or downgrade somewhere. Or, if you guys really do not know what changed about the auto 3d motion. I have a exported version prior to this update, as well as the project file in the editor. compared side to side it is nothing like before.
Apr 15
Thank you for your reply. Please send the problematic project file or a video so we can quickly locate and fix the issue. You can share it via a cloud link or any other method.
Apr 15
Sure, please take the time to review what I am showing you. There are not many things that have convinced me to pay $200 within 1 day of testing out software. Below are the exact same clips.
This is BEFORE:
THIS IS AFTER:
https://focusee.imobie.com/share/9b0e7c238f5343d6b05907a39c950a61?FocuSeeVideo# "TraderWaves - Connect, trade, analyse and ea 2026-04-12 18-20-30"
It is SO clearly different that something has changed and it’s completely ruined the auto 3d motion. The manual controls are useful when making fine adjustments but before the auto setting has done 95% of it perfectly
Apr 15
I am certain I am not the only one experiencing this, please just allow for previous versions to be downloaded on the download page on the website, similar to many other software. Or alternatively revert the 3d zoom to what it was originally on all versions. Or send me the mac and windows download of the previous version before the last update. I do not want to refund this tool that I have found so useful. Thanks Focusee team
Apr 16
We’re sorry you encountered this issue. You can contact cs@imobie.com to obtain a previous version of the software. We will verify the issue immediately and consider a fix. Thank you for your support.
Apr 16
Thanks for the help guys, I loved the 3d zoom feature the minute I tried it, will let you guys know if i need more help.
Apr 16
Thank you for your support. You’re welcome to share any additional questions or suggestions. Also, could you send the problematic project file? This will help us quickly verify the 3D zoom issue.
Apr 16
All of my project files that I haven’t exported in the past, when reopened in the editor you can clearly see the zoom has changed for all of them. Below is just one example of a dozen. Please let me know if you need more examples, I can provide many. I like in Canada which is a 12 hour difference from your team, so its unfortunate we cant go back in forth past noon for you guys.
This is BEFORE:
THIS IS AFTER:
Can I know your office hours?
Apr 16
Could you confirm whether you are using macOS? We have identified this issue on Mac systems and will release a new version today to fix it.
Apr 16
Yes I am, I am very glad you guys have identified the issue
Apr 16
I was so worried it was going to be permanent, this tool was awesome with its pervious version
Apr 16
This is because we have adopted a new technical framework that changes how 3D zoom operates. We will continue to monitor the performance of 3D zoom over the next two versions. Thank you for your feedback.
Apr 18
Can you please send me the previous version files here for me to download until you push out a new update? I need it urgently to film demo videos for my software.
Apr 20
Hi, you can download the latest version directly from our official website. We have fixed the 3D zoom issue. https://focusee.imobie.com/
Apr 20
Thank you guys, I will let you know if I experience any more issues
