Skip to main content
Multiple blur zones on the same timeline
Currently, only one blur zone can be applied per screen or segment. When attempting to add a second one, an error message indicates that a mosaic already exists in that location.
This limitation severely restricts options when it is necessary to hide multiple elements at once (for example, several sensitive areas of the screen).
Suggestion: Allow users to add multiple distinct blur zones to the same segment while retaining existing features (position, size, duration).
Status: In Progress3 comments
This request was merged into another request
Comments3
  • Flywhale _飞鲸
    Feb 9
    Merged request
    1 vote
    怎么就一个马赛克轨道!
    怎么就一个马赛克轨道!
  • Nicolas Compain
    Sep 12, 2025
    Bonjour, merci d’avoir ajouté ma suggestion à la feuille de route.
    Quand j’applique un flou, j’ai presque toujours besoin d’en mettre plusieurs en même temps.
    Par exemple, pour masquer un enregistrement dans le navigateur, je peux vouloir cacher la photo de profil, les extensions installées, certaines parties de l’application, ou encore une fenêtre d’enregistrement de fichier. Cela m’évite de montrer le contenu de mes dossiers dans une vidéo.
  • FocuSee Product Team
    Team•
    Sep 12, 2025
    Thank you for your feedback; your suggestion is now on our roadmap. Also, how often do you typically apply multiple blur effects?
