Quitting the program (cmd+q) will NOT save the project and you will lose any changes to the project.
The program seems to auto-save, but I can't figure out when or what triggers a Save.
The program should support cmd+s and a menu item "Save…"
I'm using macOS.
a.galand@gmail.com
Nov 7, 2024
In my experience, the projects have always been saved, whether I save them or not actually.
Even when I "discard changes" upon quitting the app, the project file will stay in the "FocuSeee Project" folder, which I find quite annoying as it can quickly fill up the folder with unwanted projects if you're not careful.
These projects must then be deleted manually. So I'd rather fix that bug first.
FocuSee Product Team changed status to In Progress
Team•
Nov 7, 2024
Dear FocuSee Users,
We now support the option to save unfinished projects when closing the software, and we plan to make this feature more visible so you can spot it at a glance.
Best regards,
Dora
From FocuSee Team
Max Yu
Jan 2, 2024
It could. When you close your project it will ask if you want to save it. And you can find your saved projects in history.
Henrik Gregersen
Dec 28, 2023
It is really strange that you are not able to save your recording for later edit?
Log in to comment and vote
Comments6
Dec 31, 2024
hjorte@gmail.com
Dec 10, 2024
I'm using macOS.
a.galand@gmail.com
Nov 7, 2024
Nov 7, 2024
Dear FocuSee Users,
Best regards,
Dora
From FocuSee Team
Max Yu
Jan 2, 2024
Henrik Gregersen
Dec 28, 2023
