we NEED sound channel in the timeline !!!
i use it like this , i record the vo , then i record screen , then i am supposed to be able to import my vo sound file into the focusee editor when editing the screen recording to sync and edit it according to the vo. WE REALLY NEED this feature added ASAP
This request was merged into another request
Comments4
FocuSee Product Team
Feb 11
Thank you for your feedback. We will start researching this feature as soon as possible. If you have any other suggestions, please feel free to share them.
Feb 9
Thank you for your feedback. In your normal workflow, how do you usually align the audio with the video?
amrgaming2121@gmail.com
Feb 9
For now i just donot edit in focusee at all becuase of that . Which is time consuming
Apr 2
Thank you for your reply. We will support adding audio in the near future.
