Skip to main content
Auto Crop Video following mouse position (like Auto Zoom)
It helps to make a mobile portrait view video. I want to crop 9:16 video, the crop frame always follow the mouse and make the mouse in frame. Pair it up with auto zoom, it is easy to make video of any width height ratio.
Status: Completed13 comments
Log in to comment and vote
Comments13
  • molhym s
    Jan 31, 2025
    this is a Must !
  • QA Q
    Nov 15, 2024
    I fully agree, and I also need this feature quite a lot, because very often we need to create videos in different aspect ratios using the same video source, such as 16:9 YouTube videos and 9:16 TikTok videos.
    Screen Studio can accomplish this function very well, but currently, Focusee cannot
  • FocuSee Product Team changed status to In Review
    Team•
    Nov 13, 2024
  • burylogabriel@gmail.com
    Apr 2
    Merged request
    22 votes
    Split screen
    It would be great if it was possible to fill the entire screen at 9:16 aspect ratio, because currently you can only expand the recordings to the edges but not beyond, so you can still see the colorful background behind the recordings
  • dkassar
    Apr 2
    Merged request
    1 vote
    Add “Always Keep Zoomed In” Option for Vertical Videos (9:16)
    FocuSee is missing one key feature for vertical content creators. When exporting in Vertical (9:16), we need an option to keep the video zoomed in automatically so the screen is always focused on the area of action.
    Otherwise, it becomes too small to read. Screen Studio has this under “Always keep zoomed in” — it would be amazing to see something similar in FocuSee, ideally with smooth motion tracking or cursor following. This would massively speed up vertical editing workflows.
      Team•
      Oct 13, 2025
      Thank you very much for your feature suggestion! We’ve recorded your feedback and will carefully evaluate it in our upcoming product iterations. We truly appreciate your support for FocuSee and look forward to hearing more great ideas from you!
  • Abdulrahman Alotaibi
    Apr 2
    Merged request
    5 votes
    Full-Screen Vertical Mode
    Current Issue: When recording a screen and rotating the video to vertical, the video remains in a small square instead of filling the screen.
    Proposed Solution: Add a "Full-Screen Vertical Mode" option that automatically adjusts the video to fill the entire screen when rotated vertically.
    • David Valls y Machinant
      Aug 26, 2024
      Very Good Idea.
  • Neto Duwe
    Apr 2
    Merged request
    4 votes
    Dynamic Video Format Adaptation (9:16) with Cursor-Centric Recording
    When editing videos that are originally recorded in the 16:9 format, there is an increasing demand to adapt them to the 9:16 vertical format for better compatibility with social media platforms that favor vertical viewing. However, the issue arises when the video is cropped to fit this new format, leading to the loss of significant screen information.
    To address this, I propose the development of a feature that would track and center the mouse cursor during screen recordings. This would ensure that during editing, the vertical 9:16 format could be utilized without losing crucial parts of the content, irrespective of the mouse movement or window changes throughout the recording. Such a feature would greatly benefit content creators who wish to tailor their tutorials, demos, and presentations for various platforms without compromising the visibility and completeness of the displayed content.
    I believe this functionality would substantially enhance the software's adaptability and editing efficiency for diverse video formats and hope it can be considered for future updates.
    This structure and content should communicate your idea effectively to the software development team or the community where you’re submitting the feature request.
  • wen134652@gmail.com
    Apr 2
    Merged request
    2 votes
    9:16竖屏模式缩放的问题与讨论
    9:16竖屏模式的时候,关闭固定缩放区域的功能后,视频本身缩放时会不停向上或者向下位移同时缩放,会觉得画面很杂乱,不可以让缩放是基于中间点的轴吗,那点击了固定缩放区域,放大后画布本身又不会放大了,很矛盾的功能。
    When in the vertical screen mode at 9:16, after disabling the function of the fixed zoom area, the video itself will keep moving up or down while zooming, making the picture look very messy. Can't the zoom be based on the axis of the midpoint? Also, when the fixed zoom area is clicked and the video is enlarged, the canvas itself does not get enlarged. This is a very contradictory function.
      Team•
      Jan 28
      非常抱歉给您带来困扰。关于缩放方向的问题,是由于系统会根据您在画布上的点击位置(即操作中心点)自动计算缩放变换的基准坐标。若您希望实现以画面中心为固定轴的缩放效果,建议切换到手动缩放模式,并在偏好设置中启用“固定中轴缩放”选项。此模式下,画布将保持静止,仅画面内容按中心点进行比例缩放,您可以根据创作需求自由选择适配的模式。
      英文翻译
      I apologize for the confusion. The zoom direction changes based on where you click on the canvas, as the system automatically calculates the transformation coordinates relative to your click position. If you need center-axis zooming (where the canvas remains static while only the content scales uniformly from the center), you can switch to Manual Zoom Mode and enable the "Fixed Center Zoom" option in preferences. This allows you to choose the mode that best fits your editing needs.
  • SOFTREVIEWD.COM
    Apr 2
    Merged request
    6 votes
    ⭐ Intelligent Mouse Cursor Tracking for YouTube Shorts Conversion ⭐
    Request:
    Enable intelligent mouse cursor tracking to dynamically adjust the video framing for seamless conversion of 16:9 videos into 9:16 YouTube Shorts
    Description:
    As a content creator, converting standard 16:9 videos into the vertical 9:16 format for YouTube Shorts often results in the original video being confined within large black borders to maintain aspect ratio. This significantly reduces the visual appeal and clarity of the content, especially when important details and action points are spread across the original widescreen format.
    Proposed Feature:
    Introducing an Intelligent Mouse Cursor Tracking feature within the video editing suite that adapts the video framing to follow the mouse cursor dynamically. This means that during the conversion process, the point of interest, generally indicated by the cursor’s location, would guide the focal area within the vertical format. This would ensure that the most relevant parts of the horizontal video are always centered and fully visible in the vertical frame.
    Benefits:
    Enhanced Focus: Ensure key actions and information remain central and visible, improving viewer engagement and understanding.
    Better Utilization of Screen Space: Maximizes the visible content area by dynamically adjusting rather than containing the entire 16:9 video within a 9:16 frame.
    Improved Viewer Experience: Eliminates large black borders and maintains a more visually appealing and professional output.
    Efficiency for Creators: Reduces manual effort in editing and adjusting focus areas, allowing creators to produce high-quality Shorts more quickly.
    This feature would be a significant enhancement for content creators who want to adapt their existing widescreen content effectively for YouTube Shorts, maintaining the essence and clarity of their original recordings.
    • Sahigo
      Aug 8, 2024
      Please also add to this the ability to select the portion of the screen you want to record! I don't want to see the bottom of my computer screen or the top bar of the browser when recording. Make it better than bandicam! Also if you can figure out a way to let users record in both formats (horizontal for normal video and vertical for shorts) at the same time or when editing it follows the mouse perfectly and centers it to the screen so you can chop a horizontal video to vertical without losing any of the mouse movements, it would be the biggest game changer ever. People are looking for this solution and cannot find it executed well!
